Motor mount help.
Old Feb 18, 2013 | 02:21 PM
FAD2BLK93's Avatar
Default Motor mount help.
Hey guys got a 2000 camaro with the LS. now that motor is being built for down the road. I have a 93 LT1 and i am going to put it in carburated for now. I have tried putting this question in the conversion section and had zero response. What motor mounts are needed to bolt LT to the LS lower mount on the frame? And anyone know the accellerator cable to use for a carb setup? Thanks. Marc
Old Feb 18, 2013 | 06:09 PM
wannaB tuner's Avatar
Not sure, but i think it requires different k-member to swap motors. Dont think you can just change mounts. If your creative you can fab it up to work, but not what your wanting to do if your eventually going with your LS1 later.
