First Fourth Gen, Starter Mods?
Thanks!
Buy a service manual - u will need it as alot of aging parts start to break.
Next is a OBD I scanner - u will use this tool the most and will not regret buying one.
Okay until your ready stay away from cam changes and vlv spring changes. The stock vlv springs will not support any performance cam and changing anything in the vlv train will get u into trouble until your ready.
Better to start with headers - i have Edelbrock because their smog legal and kinda like them though i would run long tube headers if i could get away with it.
I have a MOROSO CAI sitting on the shelf called the Honker - less than $200 with a new filter.
Another bolt on is an airfoil to the throttle body. At nearly $60 kinda expensive for what u get but u will need this as performance improves. Or u could just go to a new 52mm TB itself - most are cast with the airfoil.
U can upgrade the ignition box and coil - most boxes have an rev-limiter built it. I looked at the new digital boxes and sent an ACCEL box back when i read the instructions and now have an MSD6AL with coil ready to install (on my list) - this gives me the low rpm multispark and a good rev-limiter.
Well thats enough for now. Lets us know when u need more.
cardo
Same thing with the throttle body airfoil. Might be worth one HP but it certainly isn't a must-have item, not to mention it blocks off a large portion of the IAC path.
Headers are good as is a CAI. Manual is good. Scanner is good. All that other stuff posted above by cardo0, not so much.
Get a nice cat-back and Y-pipe to go with the headers, along with a cold air intake like others mentioned above. Once all of that is done (especially with long tubes) a tune would be a good step to take as well. The removal of EGR/AIR will throw a check engine light (doesn't harm anything) but that can be tuned out so it doesn't come on.
Also, keep up on the mainentance. Do spark plugs and wires while the headers are being done (much easier to get to), and maybe do a fuel filter as well.
Also
pacesetters coated long tubes is very popular for the price (not there y pipe though)... there was a huge thing lately on obx 1 3/4 stepped to 1 7/8 stainless headers but i think they are on hold every wheres.
