2 step Chime In.
Old Feb 24, 2013 | 09:26 AM
F0x Slaughter's Avatar
Default 2 step Chime In.
Well I tried wiring my 2 step off the clutch switch. I tapped into the brown wire coming off the switch.
Nothing.
Is it the brown or yellow wire to tap off?
I can't get my test light to go off on either one when the clutch is depressed with the key on.
Also what wire coming off the box is the 2 step?
Orange?
EDIT: Orange is the wire I am looking for.
Just not getting 12v to it.
Old Feb 24, 2013 | 09:20 PM
Low N Slow's Avatar
You will only see voltage at either wire on the clutch switch when the ignition switch is in the start position. (Cranking the starter) I wired in a DPST switch, with the switch in one direction the clutch switch works like it's supposed to, flip it the other way the clutch switch controls the 2 step. I also run this circuit through a switch that makes it only active in first gear so the 2 step doesn't activate when shifting.
Old Feb 24, 2013 | 09:22 PM
Thanks for the reply. After looking at Lingenfelter, I am just going to use a relay and get the 12v key on from the driverside fuse box.
