running a SBC under Fully Functional EFI
Old Mar 5, 2013 | 05:34 PM
Tinbender59's Avatar
Default running a SBC under Fully Functional EFI
I have been contacted by a couple of members concerning my LT1 powered truck. their questioning about putting a SBC under the EFI control. first off Yes It can be done. second Has it been done? Not yet, but yes, not yet using OBDII, but yes to the OBD1 ECU's, I hope to fix the OBDII problem. if there is any one else thinking about this chime in.
with the discovery of the '411 and the ease of adapting it, we can easily put EFI on any 4,6,8 cylinder engine. all we have to do is feed it the right signals, and it will output what we need to Git-R-Done. The unknown is the crank and cam timing signals. as a fabricator these will take just a little time on some applications. the rest is a walk in the park, if you are a little wiring savy.
the biggest obsticle is going to be you the builder, and wheather you buy into the HP pipe dream. horse power is upper RPM, touque is what you and I use everyday.
If more intrist I will continue this thread
Old Mar 5, 2013 | 06:30 PM
Chopstix's Avatar
EFI connection sells all the parts needed to do this...or edelbrock/holley/fast/etc if you want aftermarket EFI
Old Mar 5, 2013 | 06:50 PM
Ed Wright's Avatar
9-Second Club
Been putting EFI on SBCs for many years (since 1990). Been done over and over.
Very popular among the street rod set for several years.
Old Mar 6, 2013 | 05:43 AM
S10Wildside's Avatar
Originally Posted by Tinbender59
...first off Yes It can be done. second Has it been done? Not yet, but yes, not yet using OBDII...
I don't claim to be the first, but I converted a TPI engine to OBD-II nearly 7 years ago (2006). See http://www.thirdgen.org/techboard/tp...-opinions.html
I've built many harnesses for this application since that time.
To learn more about using the 12200411 PCM for 4.3L V6, SBC, LT1, and BBC engines, you can read my book. It will be released August 2013. Available for pre-sale at Amazon
Amazon Amazon
Old Mar 6, 2013 | 07:27 AM
quik95lt1's Avatar
very popular......im building a SBC 383 with a TPI injection for my truck, gonna run it with the stock 98 L31 ecm just gotta do some wiring changes to the injector harness
