School Me on Compression
But my friend that I'm doing all the work with in his shop is an ASE Master Technician so he will be there for the whole process and will check out the heads. But for the past month or so he's been pretty busy with another LT1 swap so I dont really want to bug him about mine. I just thought it would be good to get as much information as I can from you guys before me and him start on my engine.
No way in hell would I torque to 90lbs.
Might think it makes for a tighter seal but the other thing that is likely to do is pull the bores out of round.
Plenty of us have run that much and more compression without ignoring proper torque specs the way you are suggesting.
Believe the proper spec per ARP is 70ft.lbs. in three steps. Stock is 65ft.lbs.
In fact, I called ARP about this 3 years ago when I built my first LT1 because the local machine shop told me to go higher than the spec sheet when using the ARP teflon sealer. Their tech said that with their teflon thread sealer instead of their supplied assembly lube that I would be fine at 90 FT LBS for some extra clamping force on a thinner head gasket. 20,000+ street miles, 50+ nitrous passes, and lots of street play with 25+ bottles later through the same motor and we are still running... In fact, I have about a dozen LT1/SBC motors running like this without any issues. I've even swapped heads on 2 of the motors for bigger ones and the bores look perfectly fine with several thousand miles on them.
as said above though there is a torque diference in the sealant/lube used on the bolts so there is some merit to it
Now I did have a friend pull threads on his motor with studs and he tried going to 100 FT LBS, I really don't know why he did that. lol
I love it when folks dismiss the expensive, lengthy and dependable engineering that GM conducted and blindly substitute their "more must be better" modifications on something as simple as torqueing a damn head bolt. Im sure ARP will gladly replace the block should thread damage occur.
65-70# is more than enough.
You are going almost 40% over OEM spec. The bolt may tolerate this but you are very likely pulling the tops of the bores out of round. You are really want to pretend 8% over OEM and 40% over are similar?
I would also ask the question again about how many times did you do this with proper torque spec and have it fail?
http://arpinstructions.com/instructions/134-3601.pdf Here are the written ARP instructions. It even mentions using thread sealer without mention if jacking the torque spec up 21% over spec as you say the 800 line jockey told you to. I would trust that over the person answering the 800 line has to say.
