Big turbo 383
I have been getting great info off of here for years now but never posted any of my builds. YET.
I started a build few months back that is new to me and i need some expert help. its a 97 SS M6 383 lt1 with 210 AFR heads solid roller. The lt1 is not new to me but going rear mount on the turbo is. I need to know what a good start for a custom cam be? the engine is going to be a dog on the low end I know that not because of rear mount turbo but because of the 210 AFR. I kept the comp. high with flat top 4 valve release pistons and 65cc heads that run 2.080intake and 1.60exhaust to help with power and torq. down low. im shooting for 800whp id like to keep the turbo large to reduce exhaust pressure and not over run or stress the turbo. i know alot of people might say that my comp. is to high but i have had better success with high hp street cars keeping comp 10.1 or higher.
again i cant tell you how helpfull you have all been maybe i can help the next guy with the Trial and Error i might run into with this build.
Feel free to ask any questions you may have im sure there are pleanty as I left out alot of info.
Far as info needed what PCM are you using?
If staying stock pcm I would just stay hydraulic as you wont have the rpm potential to really make a solid shine and the solid setup will cost a LOT more.
What are you planning on running through it? Race gas? Alky? Meth?
Also what type of IC, if at all?
Myltwon thanks for posting and if you have any suggestions on IC im all ears.
