lt1 flywheel balance
Old Apr 4, 2013 | 09:21 PM
andye250's Avatar
Default lt1 flywheel balance
i have a 1993 camaro i'm trying to put together the motor i pulled out of it spun a rod bearing, i am purchasing a lt1 out of a 95 caprice and it's an automatic my car is a t56 6 speed i was wondering if i could bolt my flywheel directly to that motor and not have to worry about anything and drive it i plan on later putting a cam and intake on it i don't have a maf sensor on my if that helps,
Basically can i bolt my flywheel and clutch to the automatic motor were the flexplace is and not have to worry about balancing it.
thank you very much in advance,
Andrew
Old Apr 4, 2013 | 09:55 PM
andye250's Avatar
please need help would it be cheaper to rebuild it or buy another motor for 500
dollars
Old Apr 5, 2013 | 07:38 AM
93M6Formula's Avatar
You should be just fine bolting it on there.
