TPS issues of high idle
Old Apr 7, 2013 | 10:03 AM
blk3rdgen91's Avatar
Default TPS issues of high idle
I have just finished tuning my 24x converion cam, and ported stock heads. After that my tuner noticed that the CEL light was coming on he cleared it stating the TPS was no good and he was right and after he did that I had surging idle problems, so I replaced with advanced autocrap TPS and now my idle is still surging at around 1200 and stays there. I adjusted the TPS and my volts at idle are .69 and I know everone says .67 but Ive read that there is a range and im in it. So what could this be i checked for vacuum leaks and nothing surges when i spray brake cleaner around the intake. Any advice?
Old Apr 7, 2013 | 11:20 AM
RamAir95TA's Avatar
It is not the TPS. Have you verified there are no vacuum leaks and checked the IAC counts?
Old Apr 7, 2013 | 11:43 AM
I have checked for vacuum leaks and havnt found any, but havnt done IAC counts. thing is my idle doesnt vary it says at 1200 which i though the IAC symtoms are more like low idle If i am idling high im getting more air correct
Old Apr 7, 2013 | 11:44 AM
so why drill out a hole to make more air come in?
Old Apr 8, 2013 | 10:57 AM
BALLSS's Avatar
you need to scan the car IAC counts to determine if that is the issue. They want to be 30-35 (32) at idle, engine at operating temp.
did you install a larger TB?
Old Apr 8, 2013 | 03:36 PM
stock throttle body, and whats getting me is once i unplugged the tps and run it in open loop. No problem with the idle it idles at 800 right where its set to idle at and doesnt move from 800, its driving me nuts!!
