Need Help/Opinions(long)
Replaced injectors/retuned the ecm, car then developed a miss/intake backfires/bucking...tuner looks into it and cannot find the cause. He looked at it closer to find some pinched wires in the engine harness and fixed them which cleared up the miss/intake backfires/bucking. He also doesnt think its a mechanical problem. He checked compression, spring pressure, and valves.
However the car now has no power on acceleration, it cruises good/smooth, idles good but when it goes WOT he describes it as "having less power than a stock lt1" He looked over the air/fuel/knock values and he says everything shows good. I just dont see how it doesnt have some tell tale numbers when he is accelerating.
He says the 93 is kind of a bastard year to watch things as they run and is suggesting that something in the harness may be culprit and thinks a new one will clear it up.
Are 93s really that hard to diagnose on wot pulls? I dont understand why it was fine for 2 days and then went down hill after it was retuned on the new injectors.
Should I just grab a new harness being the factory one is 20 years old...Should be be able to read the cars values when the power drops and see when certain things get out of line? If hes saying the mixtures and voltages seem good shouldnt the car also be running fine?
Ive hit a 6 month brick wall with this car and Im frustrated beyond belief that the "f body specialist" in my area cannot figure it out knowing that if he cant figure it out how the hell am I suppose to?
Car is 93 m6, cammed, heads, 2 new optis, o2s deleted, new 36lb injectors with tune, tried 3 sets of plugs, new coil, new prom slot soldered in, checked springs, valves, compression, leak down test. various other tests...no power at WOT
One of the "voltages" your tuner could have been looking at when it goes flat is your O2 sensor voltage. Would be a very handy thing to know. :-)
