heats up fast
Old Apr 15, 2013 | 07:02 PM
DisturbedTA's Avatar
I left the old collar on the old water pump
Old Apr 15, 2013 | 07:12 PM
RamAir95TA's Avatar
You didn't reinstall the drive coupling?
Old Apr 15, 2013 | 07:31 PM
No
Old Apr 15, 2013 | 09:49 PM
Well drove it 18 miles! First 8 ran fine but now stuttering and won't rev up smoothly
Old Apr 16, 2013 | 05:26 AM
bufmatmuslepants's Avatar
We've all made stupid mistakes, don't take it too hard. I flipped out and posted a huge thread about a misfire and found a plug wire cut in half by my serp belt once.
As far as the misfire, how hot did you get it? Go over all your plug connections and make sure they are clicked tight, on the opti and plugs. Also check your opti harness, and coil to opti plug.
Old Apr 16, 2013 | 05:55 AM
Bad Chad's Avatar
Originally Posted by djjab57
I blew a head gasket few months ago from one small error, I switched the top 2 small hoses on the radiator. Check make sure there on the right port
How about you man up and Pay for that head gasket repair...
https://ls1tech.com/forums/texas-mem...a-djjab57.html
Old Apr 16, 2013 | 07:55 AM
jiveass's Avatar
Old Apr 16, 2013 | 08:27 AM
SS RRR's Avatar
Village Troll
Originally Posted by matt94z
Are you opening the bleeder valves on the hoses and water pump housing?
Even though this was not the problem doing this is not the right way. You open both screws coolant will escape through the lower bleeder screw since there is not enough pressure to push coolant up through the heater hose (where the other bleeder screw is and will keep letting air in through the top bleeder screw. Proper way is to open the lower bleeder screw, let the air out completely, close it and then open the top/heater hose bleeder screw.
Old Apr 16, 2013 | 08:44 AM
^^^^ this is how I did it. I'm going to drive it today and see how she acts she never got hot again just thinking maybe the opti got lil wet during the water pump issue or could use a fuel filter since is the one that's been on there since it sat in 09
Old Apr 16, 2013 | 08:59 AM
Puck's Avatar
Originally Posted by DisturbedTA
Attachment 398984
Attachment 398985 so lollipop what's wrong with this pictures
Damn dude chill with the RTV . All that extra that squishes into the port will break off and clog up your radiator and heater core.
Small bead, let it skin over, then install .
Old Apr 16, 2013 | 09:24 AM
SS RRR's Avatar
Village Troll
... or no sealant at all. Gaskets are good enough to seal.
Old Apr 16, 2013 | 09:51 AM
  #32
Poppacapp's Avatar
Did you get your headgasket problem straightened out? How did that go? Who did the work for you? Have you paid them yet even though they gave you your car back? Man up and do the right thing. Karma is a bitch.
Old Apr 16, 2013 | 05:49 PM
  #33
Lmao! My bad i'm nervous boot the opti getting wet lol
Well my fuel pump is my problem now does trex still have the 255 replacement pump for 100$? Orwhere can I get a 255 pump from?
Old Apr 16, 2013 | 05:52 PM
  #34
And thank ya so much f for being there when I needed advice! Much appreciated:-) :-)
