Keep it stock but$
As far a handling, I suspect a set of heavy duty Bilstein’s will give me the best bang for the buck and since I will not be racing I don’t see the need for a “dial-up” suspension. However, I have heard a strut tower cross brace might help, but just like all the misinformation on CAI’s there seems to be no scientific data for spending a dime here other than the power of suggestion and another component to wax when showing your shiny LT1.
The stock undersized brakes may prove to be lacking on the ‘Tail” and some mods needed. Any thoughts on newer gen replacement pads? Of course a new C5 set-up ($ 1500-2000 installed?) or a salvaged 98 and later F system (at $ 600-1000) installed are options but probably not a practical investment.
Looking for facts, not opinions or theories. Thanks
He will tell you what works, what doesn't and won't just try to sell you a bunch of parts.
Use your factory intake elbow from the MAF to the TB. It actually flows plenty. The ebay elbow might actually cause a loss in power. As for the rest of the CAI is concerned, it should be fine as long as it gets the filter out of the engine bay.
Also, the Eibach Pro kit is known for the rear springs sagging and it costs the same as the Strano kit or BMR kit which are much better. Just do either the Strano springs and Bilstein HDs or BMRs with Bilstein HDs, or keep stock springs and get a set of Strano sway bars. $250 for springs, $400 for bilsteins.
