lt1 with 700r4
Old Apr 23, 2013 | 09:24 AM
atkinsson's Avatar
Default lt1 with 700r4
what do you need to bolt up a 700r4 to a lt1? do you need any adapters or spacers or should it bolt right up to everything. do i need to chaing flywheel or anything .. any help thanks atkinsson.
Old Apr 23, 2013 | 09:39 AM
Chopstix's Avatar
mine bolts right up using a OE flexplate...I now have an SFI LT1 flexplate
Old Apr 23, 2013 | 09:44 AM
atkinsson's Avatar
cool how about drive shaft langths they stay the same?
Old Apr 23, 2013 | 09:52 AM
duh's Avatar
duh
The 700r4 is also known as the 4l60. No E. it was factory installed in 93 f bodies. Your 4l60E crossmember and any driveshaft will work. Make sure you have a 93 throttle body so that it has the provision for the tv cable.
Old Apr 23, 2013 | 10:09 AM
atkinsson's Avatar
thanks for the help gents.
Old Apr 23, 2013 | 10:39 AM
Ed Wright's Avatar
9-Second Club
There you go.
Old Apr 23, 2013 | 11:54 AM
DisturbedTA's Avatar
93 tb has the provision for the TV cable
