Throttle body bypass please help!
Old May 3, 2013 | 04:10 PM
ManMuchwano93z28's Avatar
Default Throttle body bypass please help!
Is it possible to do the free mod. Throttle body bypass with a bbk 58mm if so can someone tell me how to do it..??
Old May 3, 2013 | 05:53 PM
96lt1m6's Avatar
Depends on the year model. My 96z was super easy just disconnect the water line that goes from the radiator to the TB and place it on the steam pipe line done deal I think I cut a little off the hose aswell. I believe 95-97 are the easiest to do whereas the previous years require a new 3/8 hose for under $7.00
Old May 3, 2013 | 06:19 PM
Mine is a 93 I just basically disconnect the line under the drivers side and disconnect the line that goes to the vale cover and then Connect the 2 together right..???
Old May 3, 2013 | 09:33 PM
shbox's Avatar
Line that goes to the valve cover? Stop right there! Your gonna feed coolant into your crankcase through the valve cover?
What you do is disconnect both the coolant hoses going into the bottom plate of the TB and join them together with a hose union (barb) and clamps. Couldn't be simpler.
Old May 3, 2013 | 09:35 PM
lt1_2buku's Avatar
Woah!!! I pray he reads your post before he does that. It connects to the hose that runs to the back of your heads. NOT the valve cover. If needed lmk and I can take pic of mine for you.
Old May 3, 2013 | 10:50 PM
Ya thanks guys I didn't do it yet thank god I couldn't find another line on the left side so I asked first I was a little confused about that and thinking how it would work... So there's to lines on Each side of the tb at the bottom... I couldn't find the one on the left only the one going to the valve cover can u show me some pictures of this being done..?? Cause this is confusing me
Old May 3, 2013 | 11:10 PM
lt1_2buku's Avatar
I will take some in the morning and send them to you. PM me your cell if youd like and I can just text them to you.
Old May 3, 2013 | 11:25 PM
I just sent it in a pm
 Michael S. Palmer
Old May 4, 2013 | 06:30 AM
96capricemgr's Avatar
get someone to weld the hood shut to protect the car from you.
Old May 4, 2013 | 01:25 PM
lt1_2buku's Avatar
Video sent. OP not everyone was popped out the cooter with the knowledge of where/why the coolant passages are routed the way they are. I know I wasn't. The only way to learn is reading, twisting wrenches, and asking questions.
Old May 4, 2013 | 02:32 PM
ascastil's Avatar
video sent. Op not everyone was popped out the cooter with the knowledge of where/why the coolant passages are routed the way they are. I know i wasn't. The only way to learn is reading, twisting wrenches, and asking questions.
agreed 100%
Old May 4, 2013 | 11:43 PM
shbox's Avatar
You look for a coolant line going into one side of the TB and another going out the other side. It was already noted that they are on the bottom. Picture even posted. You take the two hoses off the TB and join them together (hence the term 'TB bypass'). I can't understand the confusion.
Old May 5, 2013 | 01:37 AM
I did it now.. I didn't see the one on the passenger side. Thanks for helping/making fun of me guys lol is it a must to cap the tb..??
Old May 5, 2013 | 07:22 AM
VAformula's Avatar
No, because now you have nothing going through there? Not a must, but a lot of people do it.
Old May 5, 2013 | 09:13 PM
DisasterFormula's Avatar
Best picture I've seen regarding how to do this mod. Why can't I find it on your website?
Old May 6, 2013 | 11:51 AM
wrd1972's Avatar
Old May 6, 2013 | 01:53 PM
SS RRR's Avatar
Village Troll
Originally Posted by wrd1972
Same thing could've saved you a whole lot of time and trouble before your valve float issues, eh?
Old May 6, 2013 | 04:04 PM
shbox's Avatar
Because it did not come from my website. I found it with a Google image search.
Old May 6, 2013 | 04:09 PM
Sounds like an issue that needs to be resolved!
Old May 6, 2013 | 08:12 PM
wrd1972's Avatar
No I dont agree Richard. I have all of the skills, tools and mechanical knowledge to properly do anything required on my vehicle. I got burned by not having the experience of spec'n my parts because I am not a racer and did not have significant high performance knowledge. But nice try.
