rocker geometry help
Old May 10, 2013 | 10:40 AM
guppymech's Avatar
^^^ I hope that rocker is just a spare you were experimenting on.
Old May 10, 2013 | 10:56 AM
05_quick4door's Avatar
Nope.
Old May 10, 2013 | 12:30 PM
You concerned with it coming apart?
Old May 10, 2013 | 01:05 PM
guppymech's Avatar
Well yes, the lower trunnion area is the most highly stressed part of the rocker. You could get some other rocker studs with a different radius instead of modifying what are some of the nicest aluminum rockers out there.
Also aluminum shavings undoubtably got inside the needle bearings.
If you were going to put a 'small' radius on the inside corners of the rocker trunnions it should be as smooth as possible to avoid stress risers that will cause a crack.
You are free to do as you want with your parts, but I don't believe what you did to the rocker was the right way to fix your problem.
