because i dont know
Old May 12, 2013 | 10:57 PM
05_quick4door's Avatar
Default because i dont know
What is a real number that a 383 le2 combo will make with a le4 cam(240/240 600 lift I think on a 108)
Build is around 12:1 (haven't cc head) .030 quench with the le2/le4 combo. Going through a 6speed and a Dana 60.
I ask because I am honestly its going to be slower than my hay hauler still. It was a crew cab Colorado with a 76mm on the i5. Trapped 114 on a terrible run at 14 lbs. It saw 20 regular on the street.
What should a full weight car trap with this setup? I'm not concerned with et. Too many variables.
Old May 12, 2013 | 11:25 PM
BOOSTED AFR's Avatar
Depends on rear end gear a little bit. That being said, despite the weight and the inefficiencies of running a Dana 60 you should have 114 covered.
Old May 13, 2013 | 08:05 AM
It has a 4:10 gear in it.
What do you guys trap in similar setups?
Old May 13, 2013 | 09:22 PM
94zrag's Avatar
You have my setup. It's going to depend on how well you can drive. Once you get your shift points down I assume you'll be somewhere around me, maybe a little quicker.
Old May 14, 2013 | 12:27 AM
You wouldn't happen to have any idle clips would you?
How much heavier are verts? 200-250 lbs or so?
Old May 14, 2013 | 10:18 AM
sweetbmxrider's Avatar
I would hope you are over 120 at sea level else something is fudged up or mismatched.
Old May 14, 2013 | 12:24 PM
Alright well that makes me feel better.
Its going on DD duty for a while I think. Merging on the highway is a moving target in Dallas
