MAP sensor question...
Old May 18, 2013 | 07:12 AM
CALL911's Avatar
Default MAP sensor question...
Right now I have the factory 1 bar MAP sensor. I am getting ready to have the car re-tuned on the dyno, and the tuner is recommending a 3 bar.
What I want to know is; will the new 3 bar MAP sensor just be a direct plug and play for my factory 1 bar? Or will I need something else?
This was the one I was going to get> http://www.efisource.com/shop/gm-sty...sor-w-pigtail/
Old May 18, 2013 | 08:20 AM
CALL911's Avatar
From what I have gathered, a 2 bar map sensor would be fine up to about 14.7#'s of boost, then a 3 bar would be required.
I would barely see 15#'s of boost on a very cold day on ideal conditions on my previous setup. Most of the time I would see about 13#'s of boost. I am now in the process of going with larger heads (AFR 227's over my previous AFR 180's), so I am guessing I'll see even less boost.
I am still leaning towards a 3 bar, even though it sounds like the 2 bar would probably be fine.
Any thoughts on this also?
Old May 18, 2013 | 08:31 AM
robsquikz28's Avatar
http://www.ebay.com/itm/Brand-new-3-BAR-MAP-SENSOR-With-PLUG-Turbo-honda-mitsubishi-gm-acura-/140962533288?pt=Motors_Car_Truck_Parts_Accessories&hash=item20d2058fa8&vxp=mtr
I have used this one many times for customers. I use a 1/4 npt to 1/4" pipe and use a hose to connect it to the map sensor with clamps. Then wire in the the connector.
BUT you have to drill the intake for the npt fitting or use the egr tube block off plate and install it there. But still use a npt fitting.
Old May 18, 2013 | 11:28 PM
Bigtoyz's Avatar
I got a GM 3 bar and if I remember correctly it plugged right in and mounted like the factory one did. Think it was from trans am turbo car from the 80's if I remember right.
Old May 20, 2013 | 10:42 AM
T/A KID's Avatar
If you go with a 2 bar you can run more than 15lbs, what I do is go into the PE table where you make max boost and add fuel in that way. A centri car is linear anyways, works fine.
Old May 21, 2013 | 03:31 PM
SRZ's Avatar
SRZ
Only modification is slotting the female end of the plug going into the MAP. That's it Ben.
Old May 21, 2013 | 08:44 PM
CALL911's Avatar
Ended up going with a 2 bar anyways. I'm not gonna see 15+ pounds so it made sense.
