lt1 fuel pressure drop
for any help.
The regulator's job is to keep fuel pressure steady when compared to manifold vacuum, what this means is when read by a gauge referencing atmospheric pressure is at times of high vacuum the fuel pressure will appear to drop and appear to rise under low vacuum conditions like WOT.
At idle with the vacuum line on 46 is high, that is about what I would expect with the vacuum line off simulating no manifold vacuum/WOT. Manifold vacuum will spike when you close the throttle after the rev and then you should see the needle drop.
Check the pressure with the vacuum line disconnected.
Had you not had that first line in there you would have given some great advice AND not seemed like such a *****.....
