DTC 33 rough idle in gear
Old Jun 15, 2013 | 01:40 PM
Slow94's Avatar
Default DTC 33 rough idle in gear
Car is 94 Formula A4 and throwing a DTC 33. Car is having rough idle while in gear only. Does this sound like an intake leak? What is good way to test for intake leaks? Carb cleaner?
MAP sensor is testing fine.
Oh also the only time the MAP kPa is above 80 is when the car is off... while its running it is down around 60-70.
Or could an exhaust leak at the flange cause this? Cause I'm 90% sure I have a leak at the flange
Old May 23, 2014 | 06:58 PM
flyinZ's Avatar
TTT. I had this code pop up on me last week.
