Help cleaning up coolant lines - pic
Old Jul 1, 2013 | 02:35 PM
Jason94z's Avatar
Default Help cleaning up coolant lines - pic
A is hard to see, it is a rubber line that goes to the drivers side big rad hose.
B goes to Hvac which I just deleted
C goes to Hvac which I just deleted
Can I just plug all these or does something have to loop?
Thank you
Old Jul 1, 2013 | 05:07 PM
leadfoot4's Avatar
Hoses "B" and "C", that you refer to, have coolant flowing through them. Either you're confused, and meant to say "heater", or you have an a/c unit that I've never seen before.....
Old Jul 2, 2013 | 03:09 PM
Jason94z's Avatar
Sorry the H stands for heat
Looks like I need to loop A to C but since I then need to deal with B unless I get a new driver side rad house the easiest is just to loop B to C which will keep the bleeder but look the ugliest. I think that's what I'll do for now unless someone has good experience deleting more of it.
Old Jul 16, 2013 | 10:11 PM
Jason94z's Avatar
So I looped B to C
Old Jul 16, 2013 | 10:31 PM
Shownomercy's Avatar
Man-Crush Warning
Yea, that looks hack.
Pull off the hose and at least cap each nipple, best bet would be to weld em shut.
