Oil Pressure Drop at WOT
Couple of years ago I unknowingly drove 200 miles to the tuner and made several dyno pulls all with the pickup off. Good thing the pan was full of oil. No damage done. Yikes.
Also today was a little cooler out. Still dropped but not as much. Another time I was kinda losing traction at WOT in 1st gear.....oil pressure did not drop at all.
Oil pressure does not drop any lower while braking (just drops as the engine RPM's go down).
Is the oil PSI at cold idle something I need to worry about (the shakiness of the needle)?
I did get my Dad to braze the pickup to the pump all the way around(and still using the tab bolted to the pump), but that was just me over killing it.
I simply didn't feel good with the RPM's twisting up and seeing that pressure drop(revving to 6300 at the track). I had to find out what was causing it....and with much good advice did nail it.
