Is this too hot...
Old Jul 22, 2013 | 08:45 PM
Waldo877's Avatar
Default Is this too hot...
I'm a new member here, and made an account so I could ask this question. I know they say the fan doesn't come on until 220. Where is 220 on the gauge? The line got up between 1/2 and 3/4. This was in stop and go traffic, after making a couple quick stops at stores.
Old Jul 22, 2013 | 08:53 PM
96ss1664's Avatar
1/2 mark is 210 so I say that would be around 222, I would make sure both your fans are working. Next option would be is get SLP fan switch.
Old Jul 22, 2013 | 08:58 PM
Waldo877's Avatar
Interesting. With that switch installed, will it still automatically turn on if I forget? I should also note that I stopped in a parking lot later, and it would not warm up past the middle line. Idled maybe 10 minutes like that. Got out, fan seemed like it was on. AC was not. Maybe the P.O. changed the PCM?
Old Jul 22, 2013 | 09:02 PM
Waldo877's Avatar
Or rather...would installing this mess with any PCM modifications (like changing when fans come on)? I don't know exactly what had been done in terms of the fan operation.
Old Jul 22, 2013 | 09:26 PM
pancho toco loco's Avatar
The slp fan switch does not interfere with the pcm's control over the fans. If there programmed to come on at 225 or 190 they function as normal .
Old Jul 22, 2013 | 11:13 PM
shbox's Avatar
Fans don't come on until 226° and no, that is not too hot.
Old Jul 23, 2013 | 07:51 AM
Waldo877's Avatar
Whew! Thanks for the help. I'm scared to death of blowing a headgasket on this thing, as i've heard its common.
Old Jul 23, 2013 | 08:19 AM
bufmatmuslepants's Avatar
I wired mine to run any time the key is on, never gets over 190.
Old Jul 23, 2013 | 09:38 AM
quik95lt1's Avatar
IMO 220 is WAY to hot to run them espically if your trying to do performance modifications........I run my performance stuff down at 170
Old Jul 23, 2013 | 10:54 AM
Here's a thread on how to wire either an EWP or fans to run all the time for anyone who cares.
https://ls1tech.com/forums/lt1-lt4-m...mp-wiring.html
Old Jul 23, 2013 | 11:08 AM
93M6Formula's Avatar
I have the SLP fan switch and a 160 stat. It stays around 180 on hot days and when i'm at the track, I hit the switch for both fans and it never gets close to hot.
Old Jul 23, 2013 | 11:24 AM
D-Man304's Avatar
5$ from radio shack and some wire is all u need. I have mind wired up so it turns off when ing is off. Have one on- off switch and one high and low speed switch.
Old Jul 23, 2013 | 01:26 PM
draggin97s10's Avatar
Mine runs at 176 all the time...160 stat and manual fan switch...which i leave on most all of the time.
PS to the OP...Nice mileage on that baby!
Old Jul 23, 2013 | 10:06 PM
zlicious94's Avatar
Ewp and 160 stat and mine never goes over 170 and runs strong even in heat.
Old Jul 24, 2013 | 08:23 AM
How about at high way speeds?
Old Jul 24, 2013 | 09:11 AM
SS RRR's Avatar
Village Troll
Pretty easy to figure out. There is a 100* difference between the first and lash hash mark on the gauge, four hash marks after 160*, therefore each hash mark has a value of 25* after the first 160* mark. 160 + 25 = 185 for the 1/4 mark, 185 + 25 = 210 for the half, 210 + 25 = 235 for the 3/4, and 235 + 25 = 260. Simple math.
