Lt1 bored 60. Over
Old Aug 8, 2013 | 07:03 PM
bufmatmuslepants's Avatar
6mpg and 410 hp sounds like your **** needs a tune in the worst way.
Old Aug 8, 2013 | 08:30 PM
Dowdy705's Avatar
Originally Posted by BOLO
LT4 intake will bolt up and work with AFR210's and 227's as well.
As for tune goes. It was tuned by blue cat. A known tune shop that iv been to before to tune my old silverado. Very well possibly could use another tune. But car has been to an 8th mile track as the times are in the glovebox. Its 6s. Given that thats his car & he knows how to drive it. Buti havent been to the track yet because i need sum nice slicks on it is what im waiting for. But dont plan on ever spraying anytime soon. & is keeping the 5.3 really that ideal? Its got 130,xxx on it. Should i start doing anything to it in the meantime when $ is right ? If so what. Thanks.
& as far as my knowledge goes. The hp seems correct on my car as stroker usually put out 385-405hp plus full bolt ons. & seems like everyone with an f body wants a 9" & something along the lines of 400hp. I mean a c6 vette comes with 433hp stock ? Not shappy to be a poor mans vette lol.
Old Aug 8, 2013 | 08:35 PM
Dowdy705's Avatar
But with 44lb injectors, 93 octane gas. & the gas guage dont work. But all i get is 100 miles.. Tally that up. 6mpg. Lol. Cars got all supporting mods as sub frame conncectors, spec 3 clutch. Ect. Only thing i planned on doing to it. Was rotars, & prolly save up for sum. Nice black weld racing wheels or draglights. Not a fan of the pro stars on z's.
Old Aug 9, 2013 | 12:04 PM
KW Baraka's Avatar
Originally Posted by pillarpod
lt4 intake does not work with lt1 heads
The AFR 210 heads are.....OK.....wait for it.....spec'ed by AFR as LT4 heads!
My car makes 410 hp to the wheels! It sounds low. As we all say it should push more. But car is super fast. Gets 6mpg........
410HP to the wheels is real good power considering that your cam seems to be a bit mild. Having your AFRs touched up by a good head porter may be worth up to 30+ more horses; AFR 210s flow a lot, but they don't always produce a lot of power 'right out the box'.
But......going to a .060" overbore ain't gonna net you squat......it'd be a bad move.
What do you know right now about your engine......Static Compression Ratio? Quench?
Oh yeah.......that 6mpg you're getting means that you need a real/decent tune (which may also be worth another 10-20 HP) .
KW
Old Aug 9, 2013 | 01:21 PM
Dowdy705's Avatar
KW
Thanks. Intake is ported to match the heads cnc'd. & 11:42.1 compression. & what is quench ? Sorry
Old Aug 9, 2013 | 02:18 PM
Ed Wright's Avatar
9-Second Club
Which cam?
Old Aug 10, 2013 | 01:04 AM
KW Baraka's Avatar
.........what is quench ? Sorry
Quench is the distance from the piston crown at top dead center, to the bottem of the heads.
Ideally, block is decked to .005".....and.....the compressed thickness of the head gasket is .030" to .035".
This would bring your engine quench to .035" to .040".....this is optimal for a street-driven Chevy small block engine. The higher you get from this point, the less power you'll make and the more prone to pre-detonation your engine will be.
GOOGLE "Engine Quench" for more info.
Originally Posted by Ed Wright
Which cam?
Yes.....which cam and if custom.....what are the specs? It's important to know what your static compression ratio is (11.47:1) AND your dynamic compression (currently unknown). For the LT1/4 engine, 9:1 to 9.5:1 dynamic compression is the optimal range.
GOOGLE "Dynamic Compression Ratio" for more info.
KW
Old Aug 10, 2013 | 12:51 PM
NewOrleansLT1's Avatar
But isn't it true that AFR heads are speced using a .60 overbore? If that's the case those 210 heads should make more power with the bigger overbore cause its pulling more air in.
Old Aug 10, 2013 | 01:25 PM
Ed Wright's Avatar
9-Second Club
Nope!
Old Aug 10, 2013 | 02:24 PM
Dowdy705's Avatar
Nope!
Ok got cam specs ! Please reply. 585/.585 108 lsa. Custom induction grind cam.
Old Aug 10, 2013 | 02:59 PM
Ed Wright's Avatar
9-Second Club
.585 is the lift, which means almost nothing. What is the duration @.050?
Old Aug 10, 2013 | 03:04 PM
  #32
Dowdy705's Avatar
.220 dome if that tells u anything..
Old Aug 10, 2013 | 05:37 PM
  #33
KW Baraka's Avatar
Nope......
KW
Old Aug 10, 2013 | 05:40 PM
  #34
KW Baraka's Avatar
....... 510 lift hydraulic camshaft ........
OK.....I'm confused.
What's the story with the .510" cam?
KW
Old Aug 10, 2013 | 06:15 PM
  #35
Dowdy705's Avatar
KW
Sry bout all that. I havent had the car long i'm just getting peoples openions on it. I have a 5.3 motor (iron) i WAS going to trade for a .60 over spare lt1 block. But apparently. U can bore that out to obviously a 5.7 but have to use various ls1 parts to my understanding ? If so what? & what should i do to the 5.3 in the meantime just in case my 385 goes out ?
