Max Effort W/ Rods
Just for future references what Hyper’s or Forged Pistons would be a good bang for your buck?
Car is stock for now. Cam, spring, rocker swap will be here within a few weeks. (Yes you guys have heard that one too many times, then never ever hear about that build ever again) Wondering how strong these stock hyper's will last with spray 100-175 shot + custom spec cam while being a DD or if I should be on the safe side and get a set of new Speed Pro Hypers, or a great bang for buck Forged Pistons. Yes tune, recondition, balancing will be insurmountable factors. Just figured that maybe the stock pistons have lost some strength since they rolled off the assembly line. Wont know how good of shape they are until we pull the heads.
After thinking, research, study, and gambling I wouldnt be resentful if I’d needed to spin 6600+ to make adequate power. Cam ill be shooting for 330 to the wheel & + whatever shot is recommended with cam im suggested. Budget will be around 7k and then some. Finally excited to get the LT back in strong shape
If you're buying pistons, it would be foolish to not go forged!
With your modest hp goals, the stock pistons will be fine AS LONG AS IT'S TUNED BY SOMEBODY THAT KNOWS NITROUS AND THE FUEL SUPPLY IS UP TO SNUFF!
with a hyper, you screw up one single time and it could be game over. with a forged slug, your margin for error is much more forgiving
You'd be foolish to bother rebuilding a motor with hypers if you want it to last, cause youre only going to want more after so long and you'll have to clinch your teeth everytime you spray
