Engine keeps dying
get a spare spark plug.
when it dies, remove a plug wire and put it on the spare. put end on ground in car chassis.
turn over engine and report back if u got spark.
next would b to check fuel pressure w a guage.
I have a Walbro fuel pump.
A friend said to check the vats, but I never have any of the typical vats problems. Another friend said to check the ignition switch near the bottom of the steering column. I've never heard of anything like that. Anyone have any thoughts? It's gotta be some lame non essential shitty feature GM built into the ignition system! I just don't know what.
Don't mess with the steering column unless u know what u are doing and can set the ignition switch operating bar.
If it starts then shuts down then something is telling it to do so - ECM. But for what reason? No codes is strange. I dont have the factory manual for '93 but it should have a diagnose for this. U need the diagnose flow chart for '93 - before u waste any more $$$. Heck a shop manual is <$100.
cardo0
