car just shut of while driving
When i reflashed my PCM on my '94 this year the wiring connectors were feeling a little brittle but its still functional after 20 years. I dont recommend wiggling wires too much to troubleshoot because sometimes u end up with loose and broken connectors/wires u didnt have before. Myself i would just find all the ground wires to the body metal and clean them for a good contact surface then as time permits replace the opti then the engine harness.
I dont see how selling your hot rod is a fix. Every old car has problems that u need to learn and understand to master. A shop manual and scanner will help and the more u use them the more helpful they become. Selling and starting over and over again is much more expensive. Trying to reduce to just one hot rod LT1 would help finances enough but like most us enthusiasts without a hobby car u will just be looking for another.
Good luck Brian,
cardo
Car died while driving to work today, I coasted to a stop and then when I turned the key back on I didn't hear the fuel pump kick on. So i turned the key off and back on and still didn't hear anything, cranked it anyway and it fired right up and drove the rest of the way with no issues. Didn't actually do anything to get it to start.
I could get it to try to fire by messing with the opti pigtail, the end near the manifold. If I unplug it with the key on I can hear a relay click and a buzzing sound for a few seconds. If i did this it would fire for a split second like maybe only a cylinder or two had gotten some fuel. IDK just weird.
I hate intermittent problems!
While I was at the u-pullit to get the coil connector I found a t-top headliner in excellent condition cost $10
Will not know until I get to drive it a while and it doesn't happen.
One thing I can be sure of, if I pushed down on the wire going into the coil connector from the ICM the car would die. Then it would most likely fire right back up. The couple of times it didn't fire while I was concentrating on that area, I could go and pull up on the wire and it would crank right up.
I have a good feeling that this was the issue. My wiring harness is pretty ratty near all the connectors, so I'm looking forward to more issues like this. So far I've replaced the coolant temp sensor connector, ICM connector, and coil connector (grey). Thinking the MAF connector will be next on the list.
It sounds like you've possibly found the problem. Thanks for keeping this thread alive and updating as you troubleshoot the problem. Good information for me to go off of with an issue I had with my car doing something similar but it was only when I would sit at a light or stop sign. Now I'm wondering if its also related to the electrical drain problem I haven't been able to figure out.
Definitely not fixed.
Car died on the way to work this morning. Just shut off with no warning. I sat and tried to start it, but nothing. Then I sat for a couple minutes and tried again and it started up like nothing had happened.
I highly recommend getting an AC Delco or Delphi unit and then doing the LTCC conversion.
Its has a personal experience with my car. had to change optis like 2-3 times a year.
So on the fourth i decided to go AC Delco and did the LTCC. Has been running like a champ for the past 10 months. anyways those are my 2 cents.
I'm always alone and cant even check for spark.
Guess when I get paid again i'll rent a fuel pressure guage and tape it to the windshield and hope it dies within a week or so.
The car has started to cut out bad at full throttle, missing and backfiring, etc... so I'm replacing the opti. Maybe that will fix the issue, maybe not. My wife's exact word were "well it's not the opti's fault that you dumped coolant on it twice now" :/
I replaced both the opti and the coil. I think my coil may have been the culprit. I got on it the other day and the motor would just fall on it's face and cut out above about 4000 rpm when going WOT. I replaced the coil and it's stopped doing that. So it may have just been bad.
I also replaced the opti, even though the one that was on there looked really clean on the inside. There was a lot of what looks like carbon buildup on the posts in the cap. I ended up disassembling the new opti and putting my original mitsubishi sensor in it. I just cleaned all the rust out of the optics. It's running pretty good now.
Time will tell.
I actually enjoy driving the car now that it doesn't randomly die.
Of course it also makes it more enjoyable that I fixed two oil leaks, a trans leak, got new tires, fixed the windshield wipers, opti, coil, spark plugs, alternator, exhaust leaks, new O2s, and some long tubes.
