Compression or Quench?
Old Oct 23, 2013 | 09:13 PM
Ed Wright's Avatar
9-Second Club
Originally Posted by SwampWS6
No matter what my piston to deck height is????
Zero deck = zero deck hight=piston flush with the block deck at TDC. Then your quench is your gasket compressed thickness.
What do you not understand?
Old Oct 23, 2013 | 11:01 PM
SwampWS6's Avatar
That's why I asked. Some people told me I still had to measure my piston to deck height even though I told them my block was zero decked. That's why I was a little uneasy about quench. Thanks Mr. Wright! And every one else! !!
Old Oct 24, 2013 | 06:52 AM
97pontta's Avatar
I always check the piston to deck height of every piston in the engine, even if I'm told it's a zero deck. Double checking things like this during an engine build could potentially save a ton of headaches and problems. When your getting down around .035 and less for a quench you can't be guessing, you need to know exactly where that piston sits in each hole so you can make the correct decision for gasket thickness.
Old Oct 24, 2013 | 07:49 AM
SwampWS6's Avatar
Right, thats why I asked the question because I didnt really know whether to check again or not. Its my first build so I dont want any screw-ups!
Old Oct 24, 2013 | 09:27 AM
Ed Wright's Avatar
9-Second Club
If you don't actually KNOW the deck is zero, then you must check it, or have somebody knowledgable do it for you, and show you how to do it yourself next time. Don't take the machine shop's, or whoever's, word for it. You will need to buy some tools. Should also buy a book about engine building. Not just reading message boards. You get too many that don't know **** trying to give advice.
Old Oct 24, 2013 | 10:29 AM
SwampWS6's Avatar
Exactly! My fiance dad's a master mechanic and has all the tools and Ive purchased a LT1 performance build book so I can better understand clearance issues. The book just wasnt all that clear on quench. I asked the question because of the LT1 experience in the forum, so I really appreciate the help. Hopefully I'll have some dyno numbers up soon!
Old Oct 26, 2013 | 08:25 PM
96capricemgr's Avatar
Far as when quench becomes important for detonation resistance why not apply a very little bit of OBSERVATION.
I know someone suggested poor quench and 11:1 might detonate BUT reality is a LOT of heads/cam LT1s running around out there with over 11:1 compression with stock shortblocks pistons more than .020 down and gaskets in the .026-.029 range for quench of .046+. Reality is most are worse the stock shortblocks I have played with have been mostly .022-.027ish and I have seen reputable reports of up to .032.
Besides the fact that improving quench is going to raise compression and that improving quench is the most effective way to raise compression because milling the head making the combustion chamber smaller has less effect on compression than milling the block or using a thin gasket because the chamber is smaller "diameter".
Old Oct 28, 2013 | 08:06 AM
SwampWS6's Avatar
Well the heads are flat milled .050 if that makes that much of a differences? Lloyd Elliot suggested Running Victor Reinz 5898 which is .026 I think? I thought that was too thin but that was his suggestion on my application.......
Old Oct 28, 2013 | 08:13 AM
moehorsepower's Avatar
You also need to consider the parts you are going to use, The RPM you plan to spin, High RPM's, Tight quench, cheap parts, Plus thermal expansion = damaged parts..
Old Oct 28, 2013 | 08:34 AM
SwampWS6's Avatar
I got everything planned out. Scat forged everything, Mahle pistons, custom cam, dual roller timing chain, high volume melling oil pump, and TFS heads. The only thing i skimped on was the heads. I should have went with AFR's but TFS wasnt a terrible idea
Old Oct 28, 2013 | 08:47 AM
RamAir95TA's Avatar
Ditch that HV oil pump if you know what's good for you.
Old Oct 28, 2013 | 09:04 AM
  #32
SwampWS6's Avatar
Really? Why? Im just curious. . . . . . .
Old Oct 28, 2013 | 04:57 PM
  #33
You have to know your pistons are at least .005 down to use the .026 gasket and at that I would still check them all not just one.
HV oilpump is MUCH more likely to destroy the oilpump drive than it is to do anything good.
How much the heads are milled has nothing to do with quench since there was already a flat with the deck quench pad on the heads. For head milling to affect quench the combustion chamber would need to be full bore diameter.
Old Oct 29, 2013 | 07:41 AM
  #34
SwampWS6's Avatar
Thanks for the explanation 96!
