Need help finding this sensor 1993 lt1
I cannot find this CKP crank position Sensor for a 1993 LT1 .. called searched does any one ,or have a working one they willing to sell or know where or who can order one through. This is the smaller one not the regular longer type.
A crankshaft position sensor on a 1993 OBD I LT1?
I could be wrong, but I do not believe that LT1's had a crankshaft position sensor until 1996 when they went OBD II.
[FYI - I had a 1995 OBD I LT1 front cover (when I picked up a LT1 engine core) and this cover was missing the hole for the crankshaft position sensor - unlike the 96 / 97 front cover that had the hole for the crankshaft position sensor.]
Its not letting me upload the pics but use the link and it will go to the pic of what i need its at the bottom
http://www.mastercraft.com/teamtalk/...ad.php?t=58034
The 92/93 LT1's do not have a crank position sensor when running a factory ECM. The 92/93 corvette and 93 f-body share the same ECM and there isn't a CPS. Now if you're looking for this sensor in regards to the boat install, you'd have to check with mastercraft as they use a completely different ECM. They also used the Northstar coil packs as opposed to the Opti. I would look to a marina, or mastercraft dealer to make sure they get you the right sensor.
