Are the LT1s worth keeping/modding?
If you want to go 5.3, are you going to want to change wiring, k-members, trans if you have a t-56, buy the 5.3 , buy headers, odds n ends, intake setup, etc etc?
If money and time isn't an issue, go for it. I'm just saying you will have to go through all that and then some just to be able to put the motor in, then do the mods. You already have an LT1, all you have to do is build the motor and thats it, no swapping, no wiring unless you're okay with that and have the skills for that matter.
Side note on optis, opti harness, and icms. I have never had an opti fail. Took one off that sounded bad but still ran fine. I have had one opti harness break but that was my doing. Also never had and ICM fail. This is between my 96 Caprice,96 Firebird and my brothers 95 z28. Total seeing around 120k miles between all of them.
The people who have the biggest issues with optisparks are LS1 owners. The problems are blown WAY out of proportion, primarily by people who don't own and have never owned LT1 cars. (I've had mine 6 1/2 years and 40,000+ miles without missing a beat on the stock opti thus far).
Besides, if there is an issue (afterall, it is a wear item-as are ignition systems on every car on the planet) you just replace it with a quality replacement part (oem primarily). and a few hours later with hand tools and it's fixed for another 100-200k miles if installed correctly.
If someone can't spend a couple hundred bucks and use simple hand tools for a few hours, the performance car world is probably not for them anyway. A set of new tires would be more expensive than an optispark and need to be replaced far more often, but nobody ever mentions that "issue", they just accept it.
With all of that said, the LS motors are superior to the LT1 motors, but that doesn't make the LT1 motors or cars junk. The LSx is more capable, but that doesn't make LT1 motors incapable altogether. LT1 motors can get into the 11's with just heads/cam and supporting mods, and on these cars 11.50's requires a roll cage at any NHRA track. How many LS1 cars do you see running around with roll cages? Not many. People rarely ever use the advantage anywhere near its potential anyway IMO. So it all boils down to what you want to do with the car. Peppy 11-12 second street car? Stay LT1. Single digit race car or 500+rwhp street car? Go LSx.
Just my .02 of course.
that being said, find me a super clean ls1 car with 45k miles for 6250 like i found my 94 z in the same condition.....then id think about the LS. keyword THINK about it...... for street cruising with my wife and kid, shows, taking down the occasional smart azz rice burner, i am very happy with my bolt on LT1..
A good set of heads, the right cam cam and a good tune put you at 500+ fwhp easy.
My 94 with a 60e got 22 mpg with the cruise on 85 going from San Diego to Seattle. Never skipped a beat. The only thing ive done to it is replace the opti at 190k and a full tune up at the same time. Once I put the bolt ons on it will be a nice street car to play around in.
My point is several people say the 5.3 responds to mods better so wouldn't the 5.3 with heads and cam produce more power than the LT1 with similarly priced heads and cam?
