Project: Underdog
Old Nov 11, 2013 | 10:44 PM
Chopstix's Avatar
Default Project: Underdog
Picked up a 1994 Pontiac Formula a while back to use as a daily driver.
That lasted for a few months before my driving habits changed enough that I didn't need a beater anymore to keep the miles off my other cars. So I have decided to build a little "street" car to sneak up on the unsuspecting at the local drag strips.
Goals:
1) civil enough to pick up kids from school
2) 9 second timeslips
How I plan to meet those goals:
396cid, Ross Pistons, Eagle crank/rods
Hand Ported AFR 227s
LT4 Intake
T&D Shaftmounts
258/268 .6xx/.6xx 11x lsa Solid Roller
Goebel 4L60e
Vigilante 3800
Moser 12 bolt 3:73s
All the usual tubular/adjustable suspension parts.
Nitrous Outlet LTx Plate system w/dedicated fuel system.
The project is nearing completion and should be making its first passes by spring.
Old Nov 12, 2013 | 05:24 AM
BizZzatch350's Avatar
Moderator
Nice, sounds like white car part II! Look forward to seeing numbers and times
Old Nov 12, 2013 | 07:25 AM
Puck's Avatar
Motor sounds sick, should be good for 650 flywheel - and with some spray on top of that you should have 9s in the bag!
Can't wait to see how it turns out.
Old Nov 12, 2013 | 03:05 PM
MEAN LT1's Avatar
Sounds like a solid build. You get rid of the white formula?
Old Nov 12, 2013 | 03:20 PM
flyinZ's Avatar
Subscribing...Should be a good time
Old Nov 12, 2013 | 03:51 PM
Chopstix's Avatar
look in the background and you will see the white/black car ...I have big plans for that one. Plans involving an x275 88mm.
Old Nov 12, 2013 | 10:26 PM
Moderator
Nice Ray, glad to see you're keeping atleast one LT1 powered car around.
