gasket matched ports
Second sounds kind of like it is maybe a retrofit?
If a retrofit and you think you can just wire in the pcm and do zero reprogramming consider abandoning the project right now. If this is just an engine swap on an already LT1 equipped car again don't screw with the ports if you aren't willing to address the pcm. It will run fine but if you are unwilling to deal with the pcm don't bother trying simple mods either. If an L99 car receiving an LT1 then you are at the very least likely to have speedo issues without reprogramming the pcm.
Far as actually gasket matching, the exhaust ports on the heads SHOULD be smaller than the exhaust manifolds or headers to combat reversion.
On the intake side opening up the gasket surface to gasket size makes for a fat spot in the middle of the combined manifold and head port which just makes it harder for the air to flow the air having to expand to fill the fatter area and then speed back up to get down the rest of the port is counterproductive. On mild engines with unported heads the later intakes with the smaller trapezoidal ports are actually slightly better than the early larger rectangular ports because they align better.
