Heads before cam ??
Kgkern, most of your power was gained in the 1.7s, 11:1 and e85.
very true.......just trying to make a point lol
Weren't the earlier ones mechanical fans which lowered the rating because of the accessory load?
Weren't the later ones also equipped with a different intake and 10mm larger TB.
A quick googling says they changed the cats to higher flowing as well.
Also revealed the tunes differ dramatically even just from 2000-2006 not even getting into the Gen IV.
The compression ratio also raised.
So I call complete madeup bullshit on your statement FABRICATED and cherrypicked just to support your opinion here and it is about a completely different engine platform to boot so WTF are you doing posting about it anyway.
Ok let's pretend a mechanical fan places no accessory load on the engine.
That said I am finding references to the cam changing, the tune changing, the cats changing and the intake manifold and TB changed.
Found some info about the intake tract changing too.
Then there is the indisputable fact the HP changed incrementally......................
Yes the 243s added power to the 5.3l but it was a LOT less than the 35hp you are pretending.
It gained .4-.5 of compression the same year it got the heads, intake and TB upgrade gaining a total of 20hp from all of that plus whatever tuning differences there were. GM powertrain engineer tells me the later intake and TB would be worth 6hp on my 2005 5.3l so that leaves 14hp left to split up between the compression, heads, tuning and any intake/exhaust differences.
If you want to argue this PLEASE try and do so point for point.
If you feel I am wrong about the compression changing or the intake being better or the TB being bigger address those specifics.
