A couple new LT1 specific goodies
First is an LT1/F-Body specific Electric Water Pump Harness. It is designed to hide the relay and fuse behind the PCM on the firewall. It also has a warning light circuit. The cost for these will be $80
Heated O2 conversion Harnesses. These are covered with 1200 degree fiberglass braid and are plug and play for the O2 sensors, and you just make the ground and ignition power connections and you are finished!! These are priced at $75 for a set.
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
1-888-467-4491
