Injector size question
Old Feb 6, 2014 | 03:40 PM
ahritchie's Avatar
Originally Posted by 93M6Formula
But at what fuel pressure? Injector lbs/hr is also dependant on fuel pressure.
Indeed it is....however, the LT4 has exactly the same fuel pressure as LT1....41-47lbs is in spec. It's the same fuel pump.
Old Feb 6, 2014 | 03:53 PM
Alex94TAGT's Avatar
Originally Posted by Ed Wright
I hope the new keyboard expert's versafueler doesn't take a dump like they sometimes do, and leave him walking. smh
Perhaps you should learn how to install them correctly. My versafueler has been running fine since 2006 = 8 years. I'm intelligent enough to know you weren't concerned for my well-being; you were employing a poorly-executed adhominem attack to avoid substantiating your claims.
Burden of proof is on the individual making the positive claim -- not my job to go chasing down nebulous third-parties. Please post concrete data substantiating your claims:
Did you not once post here claiming a +5hp increase from running tiny injectors back-to-back on the dyno? On a 500~600hp engine, correct? So a net power increase of 1%? Can you post the graphs? Did you make any attempt to isolate whether the gain was due to the injector design, or due to the rail pressure increase? (I assume the latter).
That wasn't even my main point. My point is that a wideband should be installed on any car running excessively high duty cycles -- which proponents of small injectors routinely fail to mention. I think we can all find common ground on that point.
Which one of you guys are pretending to be an engineer? LOL
No engineer here.
I am an electrical engineer. I have designed and built control systems. I was openly accusing individuals like you of pretending to know more about control systems engineering than actual engineers, as you've just demonstrated to be the case.
I'll respond to the rest of your post later -- some of us have day jobs...
Old Feb 6, 2014 | 06:57 PM
Ed Wright's Avatar
9-Second Club
Will your blown **** outrun my NA stuff? I doubt it. I also don't have that kind of junk on mine. I have customers use those. Most are gone now.
That was 5 rwhp through a non-lock 6200 RPM converter. Any gain is worthwhile if you actually run NHRA S or SS.
If you raced at the level and against the guys I do, you would almost slap your Momma for 5 hp. Those seemingly small, at least to you, gains add up.
I sold my dyno at the end of 2010 when I had to have a couple of surgeries. I'm up and going again now. I no longer have dyno graphs.
If you ventured out into the real racing world you would fine many engine builders, tuners & racers finding the same thing. You evidently are the typical know it all engineer.
I love racing engineers. When you keep kicking their butts it's always because you spend more than them, or are cheating. Never is because you know something they don't. LOL
I'm not wasting any more time on your know it all ***.
Old Feb 6, 2014 | 07:45 PM
Shownomercy's Avatar
Man-Crush Warning
So, why does Moran recommend a 60-70% duty cycle for application similar to mine?
Old Feb 6, 2014 | 07:56 PM
Ed Wright's Avatar
9-Second Club
I have no clue about what you have, don't know his reasoning. Not interested in arguing about it. I'm done.
Old Feb 6, 2014 | 07:59 PM
Man-Crush Warning
Who is arguing?
You are quick to make a big deal out of someone disagreeing, and then even quicker to just say "no you are wrong, I am right cause I have a fast car".
I just am curious, I listened to the internet, went conservative on injectors and now am regretting that.
Old Feb 6, 2014 | 08:37 PM
Ed Wright's Avatar
9-Second Club
Who is arguing?
I told what myself and many other learned through much testing. Nobody I know of found any differently. If people don't want to use that info, I really don't care. I don't appreciate fools like that last one calling me a liar.
So, Mike Moran built your stuff? He races where more boost or nitrous is always a possibility. Not where I race, nor the engine builders I converse with build for.
If 80lb injectors make somebody with an NA car feel better, that's fine. I was just sharing what myself and others learned. Don't believe it, don't use it.
Old Feb 6, 2014 | 09:02 PM
Man-Crush Warning
No, I was using him as a source that you would credit as reliable, his injector spreadsheet plots me at the duty cycle I posted above. I am not calling you a liar, I would just like some more evidence to prove or disprove stuff. Without data everything is just opinions ya know. That guy above isn't the only train driver here.
So, you are saying that NA stuff is more suited to the smallest injector as possible?
For instance, if you size a boosted car for the "right" size injector and then you run a 1:1 reg, you now may run out of fuel as most pumps go to hell at higher pressures. My 4301 will be out of steam as I am pushing it to hold ~65psi rail pressure to make my baby 80# injectors stay "safe". Where as if I went to 96# injectors contrary to internet lore, I would have a happier fuel pump and frankly, technology these days I fail to see such a large high Z injector being difficult to tune for. Hell a ID unit will most definitely have idle characteristics most likely better than stock units would..
IDK really. Just ramblings of a LT1 guy
Old Feb 7, 2014 | 07:10 AM
Mystery Bird's Avatar
I know it's early and coffee hasn't kicked in yet, maybe I'm missing something but what would it matter weather the pump is feeding small injectors or large injectors? It's still pumping up to the pressure it's set at. I could see it struggling with a bigger injector but not a small one. If it can't keep up with the small one then the pump needs to be upgraded first right? My brain is already tired, TGIF.
Old Feb 7, 2014 | 07:12 AM
Unless you're turning the pressure down for the larger injectors???
Old Feb 7, 2014 | 08:38 AM
Man-Crush Warning
Correct, a larger injector at idle will allow for lesser rail pressure so a base ~40psi would only have the pump working to hold ~55psi at WOT.
Old Feb 7, 2014 | 09:57 AM
  #32
nitrous2fast's Avatar
I love that fact of duty cycles being discussed. How is it that an injector can be ran beyond 100% DC????
Old Feb 7, 2014 | 01:34 PM
  #33
bowtienut's Avatar
hahaha.....some of us just have that magic touch
Old Feb 7, 2014 | 03:37 PM
  #34
96capricemgr's Avatar
An awful lot of the top Stock & Super Stock racers run high duty cycles with zero issues other than running faster. Not like you spend several seconds there. I do know if you hold a Lucus injector wide open too long the windings fail sooner than Bosch. Longer than you will ever see in the car unless you are running a flying mile someplace.
Most people that work with this stuff also know the reported duty cycles seen on scan tools with factory ECUs (GM at least) are inflated. Measure them with a good fast DSO and you find large differences in the scanner and actual measurements. Not many pros go by the scan tools for this.
That help?
Like I said the wideband will tell you if an injector is too small.
Fuel pressure/injector size/fuel pump capacity relationship is another discussion.
Old Feb 7, 2014 | 04:03 PM
  #35
Originally Posted by 96capricemgr
That help?
It was a rhetorical question dumbass.... lol
But you really didn't answer the question anyway.
I also glad that you can highlight other peoples post in a lame attempt to answer a question.
Old Feb 8, 2014 | 10:06 AM
  #36
superspirit's Avatar
Originally Posted by ahritchie
I'm just gonna through this out there...how come GM engineers saw it fit to put 28# injectors on the 330HP LT4 over 24# 300HP LT1 injectors? Discuss.
I found this on the Grand sport registry:
The engine's higher rpm also exceeded the LT1's fuel injector's ability to keep up, so the LT4 got larger fuel injectors rated at 3.5 grams per second (28lbs/hr), replacing the 3.0 gram (24lbs/hr) injectors of the LT1. The larger injectors were designed to keep pace with the better breathing, higher revving engine.
That is a very good question, why did GM (who has more research $ and engineers ) do that, We know all cars are built to keep costs minimized so what did they figure out that we dont know ? I'm not looking for every last half a horsepower, or .0001 in a 1/4 mile as its over 100 miles to a track. I want great throttle response and everyday driveability and dependability. after knowing GM put 28 lb/hr injectors in the 330 hp LT4, I think I will use 30 lb/hr's with my hot cam setup, that way if I do add a 100 shot of nitrous I will be covered.
Old Feb 8, 2014 | 10:37 AM
  #37
Ed Wright's Avatar
9-Second Club
That help?
My point was a scan tool is not worth a damn for determining injector duty cycle. They do make toold that will do that accurately. A lab scope.
Old Feb 8, 2014 | 11:22 AM
  #38
Alex94TAGT's Avatar
Guys, I apologize for taking a few days to respond. The past few days have been really busy in my personal life.
Please, everyone calm down. I think we finally have enough information to walk away from this with more meaningful conclusions on both sides of the argument. And I can answer some questions regarding the erroneous duty cycle values.
I'm going to split this into multiple posts.
Old Feb 8, 2014 | 02:04 PM
  #39
bowtienut's Avatar
Originally Posted by superspirit
...., I think I will use 30 lb/hr's with my hot cam setup, that way if I do add a 100 shot of nitrous I will be covered.
That makes sense only if you're planning on a dry kit, OR if you don't currently have a fully functioning set of injectors in your possession. Otherwise, you're just throwing money away for no benefit. You're not even close to any practical limit of 24# injectors.
GM fitting the LT4 with 28# injectors had nothing to do with power output or fueling margin. It had more to do with emissions. With smaller injectors, you lose the benefit of sequential injection as you get into the higher duty cycles; the injectors stay open longer and the system starts to act more like batch fire. Batch fire doesn't make any less power than sequential
Old Feb 8, 2014 | 02:52 PM
  #40
Alex94TAGT's Avatar
First off, to Ed:
I'm going to extend you considerably more courtesy than you've afforded me, but first we have to clear up the mud.
This is not a pot-shot, no disrespect is meant, so take no offense.
1) Understand that ad-hominem, shifting burden of proof, shifting the goalposts, etc. -- are examples of logical fallacy, and as such, will never help you prove your point. Such arguments can only make you appear illogical, because they are illogical concepts. You are resorting to these because you are having difficulty communicating your tuning knowledge effectively.
2) Follow your own rules. I recall you previously argued with BigCat about this, who is running half a second quicker than you in the quarter mile. That didn’t stop you from arguing with him. If the rules don't apply to you, then they don't apply to me.
3) I would remind you that you are a professional tuner, but you are using equipment created by professional engineers and programmers. Without them, you wouldn’t have a car to brag about. You wouldn’t have tuning software. You wouldn’t be a tuner.
For what it’s worth, I’ve programmed Motorola 68HC12 microcontrollers using assembly language (I believe the successor to the 68HC11 used in our cars), and I can assure you that what you see in the tuning software is a severely simplified user interface. Assembly language is about the closest language to computer language that humans can still comprehend — it’s incredibly tedious, like building a pile of sand one grain at a time.
