need help 1996 trans am
Old Feb 6, 2014 | 05:10 PM
keith page's Avatar
Default need help 1996 trans am
I got a 1996 trans am ...was running ..car sat for some time ,, put in battery .. spins over but want start sprayed starting fluid it started ,, then died ! figured it was fuel pump .. replaced it ! no start new relay still no start ! took test lite to jumper wire under hood it has power on it ! orange wire at relay has power green & white has 2 to 3 sec of power when you turn switch ! took old wire plug for pump got a flash of power their where it plugs in at axle then it quit .... security light flashes some ! maybe its ecm ? I would be thankful for some help !!
Old Feb 6, 2014 | 05:15 PM
ahritchie's Avatar
What's the fuel pressure? If you don't know, you need to test it first. I seriously doubt your PCM went bad unless the car was flooded or something.
Old Feb 6, 2014 | 08:28 PM
criticalx's Avatar
fuel rail
Old Feb 6, 2014 | 09:26 PM
NewOrleansLT1's Avatar
http://www.mainstreamtopics.com/foru...rt-diagnostic/
Check this site out it should help..
Old Feb 7, 2014 | 10:08 AM
shbox's Avatar
Address your security light issues first. It's not gonna start with that going on.
Old Feb 7, 2014 | 10:54 AM
93M6Formula's Avatar
Sounds like a security issue to me.
Old Feb 7, 2014 | 02:09 PM
ahritchie's Avatar
Good point...mine was messing up like that when the little computer chip in the key was worn out....try a different key and see if it's the same.
