Running Bad
Old Feb 9, 2014 | 03:42 PM
98z8uup's Avatar
Default Running Bad
I have a 96 Vette, it's running real bad. It's idling up and down when the car warms up.
Old Feb 9, 2014 | 08:58 PM
98z8uup's Avatar
I change the plugs and wires in the car.
Old Feb 9, 2014 | 10:18 PM
jrwilliams95z28's Avatar
If it's hunting it could be a vacuum leak.
Old Feb 10, 2014 | 12:18 AM
98z8uup's Avatar
I will look into that.
Old Feb 10, 2014 | 02:28 AM
Catmaigne's Avatar
It only surges when the car is warm? If it runs fine when it's cold then try unplugging the MAF to keep it in open* loop, then warm it up and see if the problem persists.
Old Feb 10, 2014 | 06:22 AM
98z8uup's Avatar
Originally Posted by Catmaigne
It only surges when the car is warm? If it runs fine when it's cold then try unplugging the MAF to keep it in closed loop, then warm it up and see if the problem persists.
I will try this when I get off work.
Old Feb 10, 2014 | 11:16 AM
Catmaigne's Avatar
Oops, I meant to say open loop.
But if it runs fine when cold and acts up when warm then it could be a EFI issue. I had a similar problem when an O2 sensor went. Car ran like crap in closed loop after warming up but was fine cold.
