No start questions
Old Feb 14, 2014 | 12:04 AM
ultra 94 z's Avatar
Default No start questions
Guys need ur help just bought a 94 lt1 trans am and it will not start! Checked it for fuel pressure has fuel pressure key on when cranking looses pressure has no spark at spark plug and no spark at coil also has no injector pulse! So far I have checked all fuses and all our good! Looking at the opti spark it looks like it has been replaced and it has a red cap! Any suggestions or where to go in a direction would be great! Thanks for the help in advance
Old Feb 14, 2014 | 11:34 PM
ultra 94 z's Avatar
All these views and no help? Come on fellas ,
Old Feb 15, 2014 | 12:18 PM
ChevyOwner's Avatar
I would have the ICM tested.
I have an idea for a cheap ICM replacement, but I have no way to test it.
Old Feb 15, 2014 | 12:34 PM
cardo0's Avatar
How come no one bothers to read their DTCs - diagnostic trouble codes - but thinks we can help them more over the internet?
Low fuel press when cranking but no spark? Tells me the starter gets power but both fuel sys has leak and ign is dead. Do u want to replace them both or maybe get a code scanner?
cardo
Old Feb 15, 2014 | 12:39 PM
SS RRR's Avatar
Village Troll
http://shbox.com/1/4th_gen_tech2.html#opti_test
Old Feb 15, 2014 | 12:47 PM
ahritchie's Avatar
^Good point, I didn't realize the opti can cause no injector pulse, learn something new every day! OP, go AC delco or MSD, none of that autozone Chinese crap to save a few bucks....if you already had a red MSD like you mention and it did take a dump, go AC delco....I have a MSD on my car (no problems), however, it's only got 5K miles or so on it so not sure how they hold up longevity wise.
Old Feb 15, 2014 | 10:44 PM
ultra 94 z's Avatar
I know I need to check for codes finally got as
Scanner will be checking for codes tomorrow! Does any one know if a bad Icm will cause no injector pulse?
Old Feb 15, 2014 | 11:44 PM
ChevyOwner's Avatar
No, the ICM only controls the coil for the LT1.
I had missed the no injector pulses. I would start by testing the opti.
