So I built this motor
That or get those heads milled and run a thinner head gasket, for a performance NA LT1 you want 11:1CR MINIMUM, 12:1 + would be even better. Keep in mind this is a reverse cd engine and it's not 1970 anymore. I think that is the main thing holding yours back, who tuned it also? Does it pull hard to 6700 RPM or so (mine does)? What valve springs are you running? 1.6 Roller rockers?
I call BS on that....if that were the case, LT1's would love some boost and that's not the case. They run like crap and spark knock if you don't run 93 octane, and I trust GM more than some dude at a machine shop. Where's your "proof" on this wild unsubstantiated claim? How specifically are you calculating CR??? Combustion chamber volume = 54 cc's
Bore size = 4.000"
Stock deck height is 9.025" = i.e. piston is .025" "in the hole"
Compressed head gasket thickness = .042"
Crank stroke = 3.48"
Piston "dish" volume = 8 cc's
DO THE MATH! I wouldn't want this guy working on my engine!
http://www.summitracing.com/expertad...ion-calculator
Here's the most accurate info I've collected for stock LT1 specs:
Stock shortblock
9.025" deck height, sometimes a hair taller
4" bore
3.48" stroke
1.559" compression height of stock Mahle piston
-5cc piston head volume from valve reliefs
Aluminum heads
54cc chamber
.048-.051" stock head gasket compressed thickness
.026" piston to deck clearance (in the hole) or a little more
10.5:1 static compression give or take
I call BS on that....if that were the case, LT1's would love some boost and that's not the case. They run like crap and spark knock if you don't run 93 octane, and I trust GM more than some dude at a machine shop. Where's your "proof" on this wild unsubstantiated claim? How specifically are you calculating CR???Left bank at cylinder #1 (9.027"), cylinder #7 (9.038")
I have decked a lot of SBC'S, GEN 1 & Gen 2's. I'm sorry that you don't agree with the facts that I have seen, but then again I could care less if you agree or not. BTW, the heads are not always 54cc if you had ever taken the time to cc a set of stock heads.....
Really dude?? You CLAIM to work at a machine shop which you're just further embarrassing yourself, I would think someone who works at a machine shop would know how to calculate CR, it's basic engine building 101
I never claimed to work at a machine shop, and no, I have not personally cc'ed LT1 heads....it's not my job. Playing devil's advocate here, let's say we use your numbers to be REALLY conservative:Combustion chamber volume = 58 cc's (complete BS just to round up A LOT, LT1 actually has 54cc combustion chambers )
Bore size = 4.000"
deck height is 9.038" = i.e. piston is .038" "in the hole" (for every single cylinder...would never happen
Compressed head gasket thickness = .048"
Piston "dish" volume = 5 cc's (I stand corrected on this)
9.8:1 CR = [{(B/2)^2 * S*Pi}+Vcc+Vp+{(B/2)^2*Pi*(DH+TG)}]
[{(B/2)^2*Pi*(DH+TG)}+Vcc+Vp]
9.8:1 CR is a entire point higher than your ridiculous 8.8 CR, I'll ask you again....how are you coming up with this 8.8:1 CR nonsense? I don't care either if you believe GM, me, or anyone else who knows what they are doing, you don't seem to have any business working on engines! You are the one who can't agree on facts (how to calculate CR)! Must be smokin that GOOD isht
Hook me up bro!
A moderator really should update the "The Ultimate LT1-Newbit FAQ -Basic Engine specifications" sticky on this very site claiming 54cc....the internet has enough misinformation on it already! https://ls1tech.com/forums/lt1-lt4-m...ml#post2682252
Does the LT1 section even have moderators anymore? Or is it like "Lord of the Flies" around here now?
Here's a quote from the man himself:
If you are wanting a smaller/larger chamber, just ask and we can get you what you are looking for (as large as 59 cc, as small 50 cc).
Lloyd
http://www.grandsportregistry.com/lt1vslt4.htm
"Combustion chambers are almost identical with a negligible .4cc increase in volume for the LT4 Combustion chambers at 54.4cc's." That would make the LT1 aluminum heads right around 54cc.
As does Chevy high performance magazine....got a bunch of misinformed jokers on this forum
http://www.chevyhiperformance.com/te...1_engine_info/
Bore size = 4.000"
Stock parts most definitely do vary.
I have heard one trustworthy report of a single Fleetwood engine being .032 down in the hole but at least in my experience .022-.025 seems to be most common. One report I am not sure I trust that was .009 down.
Round all volumes up and you can't get the number anywhere near low 9s much less high 8s.
Here's my references...where's yours?
https://ls1tech.com/forums/lt1-lt4-m...ewbie-faq.html
http://www.fierolt1.com/lt1_vs_lt4_1.htm
http://www.miataturbo.net/engine-per...chamber-64407/
........that's about the norm for LT1 heads. The guys looking for 54cc chambers must be thinking of LT4 heads.
