Collector Gaskets?
Old Feb 26, 2014 | 06:20 PM
mhslax6's Avatar
Default Collector Gaskets?
I just bought some Felpro collector gaskets and planned on adding copper sealant on both sides. Is this OK? passenger side was blown out.
Old Feb 27, 2014 | 06:51 AM
leadfoot4's Avatar
If you still have O2 sensors on the car, make sure the RTV you use is compatible with them. Other than that, you should be good to go.
Old Feb 27, 2014 | 08:19 AM
SS RRR's Avatar
Village Troll
I wouldn't bother with sealant or paper gaskets. Reason being is if there is a leak it will blow out the gasket and sealant. I use aluminum gaskets. They do leak, but not enough to be bothersome and they're reusable. JMO.
