LT1 decode
Old Feb 28, 2014 | 08:21 PM
Earthquake's Avatar
Default LT1 decode
Can someone decode this motor. Im getting conflicting reports. It is LT1 5.7 opti spark 5.7 is casted on back of block. The stamped number on front is V0223WHA.
Old Mar 1, 2014 | 09:21 AM
shbox's Avatar
The biggest indicator is 327 cast into the sides front and back of the block. 5.7 will also be on the deck behind the LH head.
Old Mar 1, 2014 | 09:48 AM
96capricemgr's Avatar
What do you want to know about the engine?
Old Mar 1, 2014 | 10:49 AM
lt1-xjs's Avatar
Show some pics, the suffix code wha doesn't jive. The V0223 shows it was built in Flint Mi. on Feb. 23. The only wha code I found was a 2000 346ci. auto. I did see a whd and a whf lt1 code.
Old Mar 1, 2014 | 11:31 AM
ChevyOwner's Avatar
Are there any external differences between the 2 and 4 bolt blocks?
Old Mar 1, 2014 | 05:07 PM
lt1-xjs's Avatar
I've heard you have to remove the pan and look. But I found out 3 more suffix codes for the 1996 Corvette. They all start with Z, ZXA-lt1, ZXD-lt4 and a ZUF but the info wasn't to clear, a race block it said. Common knowledge would lead you to believe these are 4 bolt blocks.
Old Mar 1, 2014 | 06:50 PM
It is the same casting. Studded 2-bolt has reliably held over 500rwhp through an auto. IMO by the time 4-bolt really becomes worth considering you need to be looking at aftermarket caps so I wouldn't pay any premium for an OEM one.
Old Mar 1, 2014 | 07:21 PM
ChevyOwner's Avatar
Okay thanks.
I was mainly curious.
