Any way to drop front of of pan to access return line?
Can I drop the pan down and access it? I don't have the time or resources to pull the M6 or lift the motor. This needed to be done yesterday and I thought I was going to button it up tonight.
Anyway, I'm sort of imagining the type of fitting you have, and I'll go from there. For starters, you'll have to get the car SAFELY up on stands or a lift. And you WILL have to lift the engine. The pan can be dropped, not removed, but dropped, enough so if you're really good with your hands, and have a fair amount of flexibility in your fingers, you could PROBABLY get a small wrench in the pan, and remove the nut. Then you can remove all the RTV "band-aids", and reseal the fitting properly, and re-install the pan.
If you use one of the FelPro 1 piece oil pan gaskets, you can snake it under the block, and over the pan, and get it in place. The only tricky part is where the gasket goes around the dipstick opening. It takes a little patience to finesse the gasket in place there. It's not impossible, I've done it.
Since I can't see your picture, therefore see what kind of fitting "Bubba" originally used, I would think you need some sort of bulkhead type of fitting, one that will allow you to install washers/seals on both sides of the pan, then the nut to hold it in place.
Keep in mind, the oil pan is subject to positive air pressure, as the crank spins, so cutting another hole in the pan isn't practical. You'd then have to be able to seal it effectively, which would be difficult. The second plug you pictured, appears to be just a replacement oil pan plug. If so, it needs some sort of female threads to screw into, and you'd still in the conundrum you're in now.
Wish I had better news......
As you have already seen, the RTV, JB Weld, et al, "fixes" don't really work. They're "Band-Aids". You need to either get your hands in the pan leaving the fitting in place, and tighten the nut, or bite the bullet and drop the pan. Either way, my feeling is to do it right, so you only have to do it once.....
1) Move all items off the top of the intake manifold, so the flat of the intake is the highest point, then disconnect the exhaust from the manifolds.
2) Pull the motor mount bolts
3) Remove the Transmission crossmember
4) Attach a cherry picker to the LT1 and raise the engine until the top of the intake manifold touches the bottom the of firewall.
5) Drop all of the K-member bolts by three (3) threads.
6) Remove (barely) the oil pan after struggling with the front of the pan and the crankshaft counterweights.
Cursing is optional, but suggested.
