396 lt1 help
Old Mar 26, 2014 | 05:14 AM
noice's Avatar
Plasma Moly is a SUPER hard coating that is sprayed on the rings, it means that the cylinder walls wear into the rings instead of the other way around. When you use nitrous on a motor with plasma moly rings, the coating starts to flake off from the heat. Once the plasma moly coating is off of the rings, it is all over.
Plus if the rings gaps aren't right, you'll never be able to spray nitrous and not damage the cylinders.
Old Apr 7, 2014 | 04:23 PM
camaro396lt1's Avatar
Bump for any more advice.
