tranny/clutch/shifter problems?
Old May 14, 2004 | 05:36 PM
WannaZ28's Avatar
Default tranny/clutch/shifter????
After beating on my car and letting it rest/driving it safely for about 30 minutes, I try to put it in reverse, but it doesnt grab on - ive gotta shift out then shift in, this time a little harder, then it grabs. Could it be a slightly warped clutch. I had the same issue with my 79 saginaw camaro - drove the clutch for like 10k miles all warp. For these T56's, anything to worry about? I drive a 95TA M6.
Also, what are the early signs of a tranny going bad?
Anything help is appreciated.
Old May 14, 2004 | 06:19 PM
WannaZ28's Avatar
Default clucth or tranny?
Old May 14, 2004 | 10:28 PM
Gangly's Avatar
Nothing really to worry about. its hard to get our cars into reverse sometimes, especially after hard driving. what you are experiencing isnt a rare thing. your clutch wont warp, it will be your flywheel if anything. When that happens, you will get a shaking from the car when you try to initiate a forward or rear motion from a dead stop and occasionally on shifts between gears. I know it doesnt sound like solid advice, but dont worry to much about it unless it starts to get progressively worse, which RARELY happens, its just one of those things T-56's do after a lot of miles.
Old May 15, 2004 | 12:48 PM
Transamula's Avatar
mine does the same thing 107k on the clock
