smoke on deceleration (vacuum)
This is the reason I had my LT1 stock guides cut down to .500" so that I could easily run any dual valve spring required with no risk of contacting the guide. When I have installed dual springs on stock diameter guided heads, the clearance between the seal and the inner spring is around .020" or so which is very tight but not really an overbearing concern unless there is contact. I saw one car where the inner coil actually pulled the valve seal off of the seat. Not good.
[IMG]
[/IMG]See the hole in the upper left hand corner? If you have the heads ported extensively enough you will break into these holes for the rocker studs and if you dont seal the threads I could see it pulling oil through them on heavy vacuum
Might be something to check out, from the look of the valve seals you have something going on, but may not be the whole story
