How to remove crank balancer
Old Apr 9, 2014 | 01:18 PM
2fast4u1989's Avatar
Default How to remove crank balancer
Trying to remove the old opti and need to pull the balancer. I've heard not to use a puller? What do y'all recommend. Also do I need to mark anything for when I put it back on?
Old Apr 9, 2014 | 01:58 PM
shbox's Avatar
Use a puller, if needed. No need to mark anything. It can only go on one way. The spokes are not symmetrical.
Old Apr 9, 2014 | 03:44 PM
Ok cool thanks shbox. Is there any special puller or just a reg one. I heard the damper can be damaged
Old Apr 9, 2014 | 04:27 PM
leadfoot4's Avatar
The "damper" is held to the "hub" by 3 bolts. Remove the 3 bolts, and the balancer should release itself from the hub, giving you the clearance you need. As "shbox" said, the bolt pattern isn't symmetrical, so it will go back on only one way.
Old Apr 9, 2014 | 11:08 PM
shbox's Avatar
Just use one capable of what the picture shows. Nothing will be damaged if done like the pic. You just don't want to grab on the outside ring. That is what can cause damage. Sometimes they come off without a puller.
