keyed crank non keyed hub HELP!
so my question is what can i do? and if i were to remove the keys from the crank snout and slide my crank hub on would it damage the engine? what i mean by that is would it throw the balance off and ruin the bearings?
stock LT1 just has the hub pressed on. yes there is a keyway on the crank. Aftermarket hubs like ATI, etc. have keyed hubs
you can have a machine shop cut a key into your hub. $50. Or just buy one. IIRC Golen Engines sells them
I run a ATI so it came keyed.
