Stupid schrader valve problem
Old Apr 14, 2014 | 07:37 PM
Wallj's Avatar
Default Stupid schrader valve problem
I am in the process of installing a fuel pressure gauge onto my LT1. Ive been trying to remove the schrader valve core but I can't get the damn thing out. I'm using just a regular valve core remover from Autozone, but I can't get the thing to hookup and twist out. Am I doing something wrong??
Old Apr 14, 2014 | 07:53 PM
bowtienut's Avatar
Lefty loosey. It's no more complicated than that.
Old Apr 15, 2014 | 04:56 PM
leadfoot4's Avatar
Some of those valve core tools also have a "thread chaser" that sticks out of the tool, 90* to the stem of the tool. If you have one of these, you might have to knock this part out...
Old Apr 15, 2014 | 08:50 PM
96capricemgr's Avatar
what gauge are you using? Guys have had the long term weight on that fitting crack it from the pipe.
Old Apr 16, 2014 | 08:41 AM
Wallj's Avatar
I just have a little tool similar to this. Hole in the middle with two prongs.
Old Apr 16, 2014 | 08:42 AM
Wallj's Avatar
I'll be running braided fuel line from the schrader valve over behind the PCM where I'll mount the sensor then run the wires inside to a pillar pod.
