Zero Oil Pressure
Old Apr 25, 2014 | 09:08 AM
guppymech's Avatar
You may consider filing a notch in the lower land of your new drive to squirt oil on the gears as recommended by Crane Cams. http://www.cranecams.com/bulletins_listview.php?s_id=27
And also installing a magnetic drain plug to catch any future chips that my be produced and to allow you to see the problem developing before total gear failure. http://www.ebay.com/itm/Magnetic-Oil-Drain-Plug-Firebird-LT1-LS1-5-7L-Trans-Am-/310086168293?pt=Motors_Car_Truck_Parts_Accessories&hash=item4832936ee5&vxp=mtr
Old Apr 25, 2014 | 11:05 AM
BALLSS's Avatar
Originally Posted by SS RRR
If it is another plastic coupler-type, then no. You should be looking at this:
http://www.summitracing.com/parts/ar...make/chevrolet
OP is referring to the "plastic" top of the drive gear assembly, not the stock plastic collar on the oil pump drive shaft.
But yes he should be running that shaft
OP
likely when whoever did the cam swap in your car the bolt was over TQ on the oil pump drive so the plastic broke. This can cause the gear assembly to "lift" and wear the edges of the gear.
hard to say from pic of your cam if those gears are OK. Carefully check your oil & filter for shavings....they had to go somewhere.
you could put in a new gear and magnetic drain plug. drive 500 mi and check plug for abnormal amount of debris/shavings...and if that is the case your cam may be eating the new gear because the cam gear is now Fok up
pic of cracked plastic from over TQ
and that link from Crane in guppymech post about HV pumps and STOCK bearing clearances....if that is your motor...put a standard volume pump back in
Old Apr 26, 2014 | 10:16 AM
Wallj's Avatar
OP
You are correct, the mounting plastic is what's broken on mine as well as the gears so that's why I thought I needed the whole drive gear assembly. I also checked the oil pump and it still spins freely so that's good. I am pretty sure it is just a standard pump.
Old Apr 26, 2014 | 10:36 AM
96capricemgr's Avatar
Hopefully it was just that the cracked mounting tab allowed the gear to ride up and have a bad contact pattern.
If you want to try just swapping the gear assembly, I would go buy some thin oil or even seafoam or something to pour through the engine with the drainplug out and closely inspect what comes out. I would also cut open the filter hoping to find the gear shavings but NO COPPER.
Old Apr 26, 2014 | 03:38 PM
Rob's Avatar
Rob
Originally Posted by F0x Slaughter
If I am not mistaken hasn't there been cases of the pickup tube falling off causing this issue too?
That happened to me and spun the #4 rod bearing. Thankfully it was still under warranty and got a new long block, then just swapped all my mods over to the new engine at the dealership.
Old Apr 26, 2014 | 04:47 PM
great421's Avatar
Originally Posted by Wallj
...here is the cam gear, how does it look?
If all 360 degrees look like that, then your cam is probably OK, but you still need to pull it and inspect it out of the car (sorry) to be 100% sure. You don't want a single (slightly) damaged cam gear to wipe out your new oil pump drive.
So, pull the W/P, balancer, Opti, and front cover; then pull the cam, drop the pan and oil pump.
Good luck!
