Injector issue
Old Apr 27, 2014 | 12:21 AM
Bobbyb4555's Avatar
Default Injector issue
On my 97 T/A w/lt1 2 injectors aren't firing. While car was running I unplugged all injectors 1 at a time and #4 and #8 made no change in the idle. Anyone have any suggestions on what I should check first?
Old Apr 27, 2014 | 02:31 AM
neverlift17's Avatar
do you know if you have power at the non firing injectors?
Old Apr 27, 2014 | 04:46 AM
Bobbyb4555's Avatar
First thing in the morning I'll run down to work and grab my tester and find out. Give me a few hours and I'll let you know what I find.
Old Apr 27, 2014 | 07:35 AM
big lou's Avatar
Hey do you have spark on 4&8 plugs might be bad wire or plugs. I would check to see if you have spark first then go from there hope this helps. any update
Old Apr 27, 2014 | 11:32 AM
F0x Slaughter's Avatar
He says his injectors aren't firing.
Easy way to tell if the injector is firing or not is to put a screwdriver against it and your ear against the screwdriver, you'll hear a clicking. Or most of the time you can feel it click.
Stick a test light in it and have someone crank it.
Old Apr 27, 2014 | 10:43 PM
great421's Avatar
BB455 -
Check PWR and GND at the 2-pin connectors of the two suspect injectors with the engine idling; if the wiring tests OK (i.e. - no opens, no shorts to GND or B+ on either wires, and your test lamp pulses indicating B+ duty cycle), then the issue is two dirty or failed injectors.
Using an engine stethoscope, you can also listen to the injector body for the Tell-Tail "Tick Tick Tick Tick" at idle.
A dirty injector can be cleaned, but a failed unit must be rebuilt / replaced.
Good luck.
Old May 3, 2014 | 11:39 AM
Bobbyb4555's Avatar
Thanks for responding guys I appreciate the advice. Sorry it's been a while, been out of town working. So my problem seems to be only on #8 cylinder now, had injectors cleaned and tested. A couple weren't flowing correctly. Voltage on all plugs were the same, 14v with car running. Put injectors back in and #8 still makes no change when I unplug it while the car is running. Compession tested and got 130lbs. So that seems good, not really sure what do next. Very frustrating! Could it possibly be a burnt or bent valve? How can I tell? And if it is a valve can I remove the head with engine still in the car? Thanks for any help.
