Questions for a Pro Tuner
1) What size throttle body?
2) Are my 36LB injectors good for their new application?
3) With my expected hp range, what should I be looking for on the exhaust side. More specifically 1 3/4" to 1 7/8" or what ever. I'm also going with new cats (not yet purchased either).
4) I believe I need new MAF as well. I'm running an OBD1 computer on a 97, I'm guessing the car will be in the 360hp range, would a stock size maf be appropriate?
The engine is a 355 LT1 in a 97 T/A. Supporting relevant to tuning parts are;
1) OBD1 Conversion.
2) LE2 Heads, to include a gutted and gasket/port matched intake
3) 305 cam
4) 6 speed manual/4:10 gears
5) 255 fuel pump
6) Stock ram air intake
7) 36 lb injectors (as mentioned above)
I'm sure there are few other things that I missed. I'm looking to get this car tuned in a month or 2, hopefully in mid michigan. I'm 30 minutes west of Flint.
Thanks,
Ryan
As for "why not go with custom cam?", I had the LE2.2 cam previously. The car was likely never tuned as good as it should have been (multiple issues to include a blown water jacket). I averaged 16mpg on the expressway. That took the fun out of weekend spins, so I'm experimenting with a less aggressive cam.
Last edited by T/A Johnson; May 8, 2014 at 08:17 AM. Reason: questions not answered in previous reponse
