8 trouble codes. Help!
Old May 16, 2014 | 03:37 PM
indyfirebird's Avatar
Default 8 trouble codes. Help!
So I got my car scanned for DTC's at Oreilly's. I have DTC 42, 43, 44, 45, 51, 53, 54, 55
The other thing I noticed is every time I shut the car off for more than a minute or two the SES light won't be on when I start the car. Then after driving for a few minutes is comes back on. All these codes came up only about 3 mins (1 mile) after starting it.
I was thinking maybe the Computer is shot?
DTC - 42 Ignition bypass circuit error
DTC - 43 Knock sensor error
DTC - 44 Oxygen sensor error (lean condition indicated)
DTC - 44 Left bank O2 sensor error (lean condition indicated)
DTC - 45 Oxygen sensor error (rich condition indicated)
DTC - 45 Left bank O2 sensor error (rich condition indicated)
DTC - 51 PROM error
DTC - 51 Incorrect MEM-CAL
DTC - 53 System voltage too high
DTC - 53 Digital EGR Valve solenoid 1 error
DTC - 54 Fuel pump circuit low voltage
DTC - 54 Digital EGR Valve solenoid 2 error
DTC - 55 ECM error
DTC - 55 Digital EGR Valve solenoid 3 error
Old May 16, 2014 | 03:41 PM
shbox's Avatar
What did they scan it with? Some scan tools are not reliable. Several of those sound bogus unless you have some real bad problems (which I doubt at this point). It would be helpful to describe what led to you having the scan done. Need background as well as car information.
Old May 16, 2014 | 03:52 PM
I just bought the car a couple weeks ago. Changed out the plugs and wires, and also flushed the cooling system. The car runs and drives GREAT IMO. Only problem I have with it right now is the cooling fans not coming on.
The scanner they used was an Innova I believe.
Old May 16, 2014 | 08:57 PM
shbox's Avatar
Innova. Figures. Seen lots of posts of bogus readings from that scanner brand. IDK why, but they do a terrible job. You need it scanned with something else or get a cable and free software to do it yourself.
Do the fans come on when the SES does? Read info.
Old May 17, 2014 | 09:09 AM
No the codes i got read where set before the engine got hot is was at about 190 degrees
